engine tick
Re: engine tick turning black
Ayuh,... Looks like a localized Overheat,... Is this a Saltwater motor,..?? Checked the Flows lately,..??
rooooney
Shes fresh water- I guess I will have to read the manual on how to check flows- i know nothing about flows but i am assuming that -this part of the engine may not be getting cooled by the flowing water- sound correct?
soaringhiggy
bond-o
I don't know the sixs very well, but that looks like the number 3 exhaust area, tick could be a lifter collapse, or bleed down restriction and over extending the lifter, and resultant valving problems allowing the isolated overheat?
Ayuh,... The 120 is an I-4,...
But I believe that is the neighborhood of the 2-3 exhaust port...
The Tick could also be Detonation, melting the motor away....
I guess lookin' at the sparkplugs might be a Story Teller,.... Or not...
A Compression Test at the same time wouldn't hurt either...
And,...
We still don't know if the Impeller has been changed during this century,.....
rooooney
Ive only had the boat for a year so I have no idea when the last water pump service was- or impeller.
soaringhiggy
I would think a compression test is the first step, it would show valving problems, when pulling the plug it may show something straight away.
sorry, I just assumed a six.
rooooney
- From bow to stern my compression test reads
100 - 100 - 90 - 80 - PSI
All of the plugs looked about the same - fairly black
What should my next step be?
Ayuh,... Buy another boat,..??
That 1 has Lots of Issues that are extremely Expensive to fix...
rbh
could you have an exhaust leak or the valves need a set up?
rob
rooooney
Well that's not very positive
- I already replaced everything but the engine and drive-
I am looking to buy a different boat- I just want to get this one in good enough shape to sell without feeling guilty
rooooney
What kind of compression should I have? The Manual says if the compression varies over 20- 30 psi then there is a problem- I'm not that far off-
xltier
that is true.but when a cylinder gets that low its laboring.so u give more throttle to maintain speed.if its that hot it could be a exhaust leak at high revs.do a tempurature reading,maybe with a infrared thermometer.be sure u got plenty of water flow.hth
Ayuh,... You're the 1 who put the Cart, ahead of the Horse....
The motor needs to be Rebuilt or Replaced....
The compression should be about 125psi or Higher on all 4 cylinders....
That motor is a rebuildable Core at Best,... An Anchor at worst....
