here is a few things I have replaced since this intermittent misfire. I have put new coils, ignition module, timing base, tested stator with a multi meter tested good, had all the carbs apart and fuel pump( everything was good all jets free flowing and clear of dirt, diaphragms good in fuel pump) all three wires to the coils are solid orange. compression on the other two cylinders is 120. I started the motor with the bottom plug out and it blew gas on my hand. spark plug has fuel on it. I have new plugs in and have switched plug wires around with the same result. it all started by boat running on a plane and suddenly losing a cylinder after idling for a bit it went back to three cylinders and ran fine. next time out ran on three for about 1/4 mile. then idled on two back to the ramp. threw more new parts at it and next time idled missing but soon as you hit the throttle would fire in all three and ran on 3 all day. drained all the fuel and refilled with premium, launched and ran about a 1/4 mi on three then dropped a cylinder. the rest of the time at idle went from 1-2 cylinders on the way to the ramp.
