Re: Engine warm up question
Ok, I will get ripped again, but<br /><br />In auto's, when I was younger I always thought it was good to warm up your engine. I have changed, don't know when but was told that the sooner the RPM's go up, the quicker the oil is distributed throughout the engine. Now I usually start and let run for about 3 seconds then go.<br /><br />In my boat, I usually will start my motor in my driveway just to make sure it will start on the ramp. I usually am nervious about running too long on driveway because I don't think the little water suction cup thing puts enough water through the engine to not damage the impeller.<br /><br />At the lake, I usually take the same opinion about my boat as my truck, I start up, but you can't push to hard because your usually in wakeless for a minute or two anyway. AS soon as I am clear of wakeless, I usually push it to about 2500 to 3000 rpm's to push oil through the motor, also to get the water through. I watch the temp guage and make sure it warms up properly and doesn't overheat (impeller again).<br /><br />My Four Winns will not let the motor go past a certain rpm point and will cut out until everything is warmed up, usually about four to five minutes. I thought something was wrong once and pushed the throttle and it cut out, got home called the dealer and he told me about the cut out.<br /><br />What do you think Lube dude? am I nuts or thinking clear?<br /><br />Spud
