am_dew
- Apr 3, 2005
- 417
Volvo AQ130C 4 cylinder, raw water cooled
I've noticed that after running close to WOT (and within WOT RPM spec for engine) for a while on a hot day, that after stopping and shutting down the engine, if I turn the key to the accessory position so my gauges are working a minute or so after stopping, the engine water temperature has risen higher than where it was while running. It will continue to rise slowly until the reading is about 3/4-7/8 way into the "green" area and then it slowly begins to drop. I don't have any overheating issues when the engine is running and when running the temperature reading is usually about 1/3-1/2 way into the green area.
This has been nagging me for a while and was just wondering if this is normal or not, and if not, what might be causing it? It seems like it would fairly normal since new, cool water is no longer being circulated thru the engine and instead the water that is in the engine is absorbing the engine's heat. Any comments? Thanks.
