engine will not shut off
tpw99
I have a 1989 60 hp Johnson. Just replaced the stator (from Iboats). While both wiring plugs were the same 5 prong; the old plug had 5 wires going in; 4 from the stator and one other from another direction. The new stator (which I know is the correct one) had the same plug with the 4 stator wires and a place for the 5th. rather than cutting the 5th wire off the old plug( which was short & in an akward location and trying to attach it to the new plug i cut the 4 wires off the new stator and spliced them into the wires going into the old plug. Same color wires and plenty of room to do it. The engine runs fine it just won't shut off; take out the key, even pull the kill switch, won't stop.
