Engine will not shut off
Pez539
I also have the same problem. My boat is a 2000 Larson 186 sei. It has the 3.0 ho volvo penta engine. I bought it last fall with engine problems. I fixed them but cannot get the boat to shut off with the key or lanyard switch. I did replace the ignition and hooked the wires up the same as the origina . There are 4 wires and none of them are a ground. There is a purple wire that is hooked up to the ignition terminal. When I use a 12 volt tester on the switch the positive is bright and the purple wire is dead. When I turn the key to ignition the power wire goes dim and the purple wire is dim. If I unhook the purple wire in the ignition position the power is normal again. I also have a problem with the tachometer. It goes to zero when I turn the key on but when it starts it is reading max rpm. Any help would be appreciated.
achris
More fish than mountain goat
Hello Pez539 and :welcome: to iboats.
We prefer you not hijack someone else's thread, so I have moved your post out and created a new thread for you.
Chris.
iboats Mod team.
Check the diode at the alternator. If it shorts, it will back feed the ignition
Pez539
Ignition switch.
I just purchased a 2000 Larson 186sei with a 3.0ho volvo penta engine. The previous owner had the motor rebuilt but never finished installing it. I got it running but it will not shut off with the ignition switch or lanyard. I have to pull the coil wire to shut it off. I replaced the ignition switch before I got it running. When I test the switch it has power and gets power to the ignition terminal. There is a purple wire on that terminal. When the wire is hooked up it is very dim on the tester. The power terminal also goes dim. When I disconnect the purple wire full power comes back to both terminals. The tachometer also shows pegged once the engine starts. Any help is appreciated.
Pez539
I forgot to mention that I disconnected the purple wire from the alternator and started the boat with the same results.
QBhoy
Does it continue to run normally when you key off ? Or is it a stutter and a rough running ? If it’s the latter it could be water in the fuel.
