Engine will not start.
boat 1
Hello.<br />I have 2002, 9.9 HP 2stroke.after I checked make sure the choke operation is working properly. When the engine started and running I choked it a few times the engine died. I knew that the choke is woking ok. After that I could get my engine started any more ,it will turn over, but will not start. Pls help.... any info will be appreciated.
JB
Re: Engine will not start.
Check Engine FAQs, boat 1.
andrewkafp
Remove the plug and crank the motor. This will clear out excess fuel/oil. Remove and dry the plug. re-insert the clean plug and try again. It just sounds flooded.
