Engine will NOT start
ericcarr2000
Ensign
:mad: OK, I just recently finished up on installing my newly remanufactured engine in her, its a 3.7 mercruiser, yeah yeah, i know....anywho, shes all hooked up, turns over fine, I have 12 volts at the coil, and the distributor, however im not getting any spark at all. Not sure if i missed any thing while hooking her up or not, but...HELP!!!!!!!!!!!:confused:
Re: Engine will NOT start
Ayuh,... How about at the Points,..??
My guess is, the distributer ain't grounded, or the points aren't closing...
ericcarr2000
Ensign
I have a black wire going from the negative side of the coil to the distributor housing, which attaches to the condensor. One more thing, after I get her started, im going to switch over to the new mallory unilite distributor.
How do I check for volts at the points?
jerryjerry05
Take the cap off.Use a test light and turn the motor over and see if the continuity is there.
A new condenser and points can be bad out of the box.J
ericcarr2000
Ensign
Ok, now when I perform the test, i get 12 volts at the battery, but when i check it at the coil, its 6.6 volts and at the negative lead, its 0.034 volts. Think I might have a bad ground or a short somewhere?:confused:
billy4hp
I would suggest going to the Adults Only sticky at the top of this forum and read 16. , 17. and 18.
Link to Adults Only section...
http://forums.iboats.com/showthread.php?t=288430
Good luck...
ericcarr2000
Ensign
Ok, I finally figured out the problem, all along it was the distributor grounding itself out, had too many grounds hooked up...:cool:
