engine will not stop running by ignition switch
ltrain
I recently removed my lower helm and moved ignition switch to the bridge. My ignition switch has 3 lugs - ‘batt’ ‘ign’ and ‘start’. When I turned the key the engine started, but now does not shut off when the switch is turned back to ‘batt’. Any and all advice is welcome and I will be happy to provide additional information if anyone out there has any ideas. Thanks in advance.
scotiany
Re: engine will not stop running by ignition switch
It would help if you gave the Manufacturer and model.
ltrain
It is a Chrysler 318 inboard with electronic ignition.
