Re: Engine will not stop.
Yes, the center wire on the distributor is normally the coil. Removal of this wire terminates the spark to the plugs.<br /><br />It turns out that my problem was an intermittent failure in the key switch, most likely in the ground terminal. I suspected the key switch initially; however, too many people felt marine key switches are pretty much military spec. and therefore, would probably not fail, so I discounted it as the source. After checking the switch in all positions with a meter and finding no problems, I checked every ground on the boat - from the wiring diagram. All tested out fine. I even ran a temporary ground wire straight from the battery. At a loss for any other explanation, I replaced the key switch and everything works fine now. Studying the wiring diagram led me to belive both the key switch and the kill switch function by shorting the coil to ground.<br /><br />Hope this sheds a little light for someone.<br /><br />Thanks to everyone for their comments and advice!<br /><br />Happy boating!!
