aggiedave98
- Jul 14, 2003
- 231
I took my boat (2004 21.5 ft I/O with the 5.0L Volvo Penta) out for the first time since the fall 2 days ago. Everything went fine. I ran it fast, slow, idled, everything was great.
Yesterday I took it out. It started right up, my friend took it around at idle while I put up the trailer. I got in and tried to take off and the engine died. Now it will only "keep running" if I keep the key in the start position (meaning where the starter should be engaged). At idle position of the throttle, it seems "runs" at low rpm and if I have it at full throttle it will accelerate if I keep the key engaged.
Could it be the key itself? A fuel problem? The strange thing is it's actually "catching" not just turning over. Not sure where to go from here. Thanks!
outdrive
TSK-SM-M
3868844
serial #4151056372
engine
3869254
serial #4012120594
outdrive
TSK-SM-M
3868844
serial #4151056372
engine
3869254
serial #4012120594
