Engine won’t turn, just beeps
Jefa79
Hello. My father in law has a 2000 Glastron with 5.0 I/o Volvo penta. It will not turn over, the engine just beeps. Acc works, blower works, etc, so I don’t think it’s battery. I have confirmed connections are tight. I replaced a fuse under the dash, kill switch appears in place and engine appears to be in neutral. Any ideas? Thanks!
Tristador
Have you tried wiggling the shifter while trying to start the engine?
Sometimes the neutral safety switch is out of adjustment and will prevent the engine from turning over.
QBhoy
Pull the spark plugs out and try it. Will tell you more info on what’s going on. Hopefully there isn’t water in there.
