I have a 22 feet boat with a new Indmar 5.7 carb engine (http://www.barrmarine.net/57l-bobtail-carbureted.html) with a Volvo Penta duoprop sterndrive.
The engine was installed new in 2015 and had numerous problems (extensive list below).
The remaining problem is that the boat will not reach WOT. It works fine when idling, but maxes 3.000 RPM (WOT is 4.600) and the boat will not plane.
The problem surfaced suddenly when drive the boat home after a short stop.
My new boat mechanic claims that it is caused by a faulty power trim pump preventing the sterndrive from being in proper position. Currently, with boat on land, the driver can only move down - no reaction when moving power trim up - perhaps a faulty switch. During last season I sure the drive could be moved up while experiencing the same problem. I have already tested and changed so many parts and am reluctant to do this new 1.000 USD operation.
This is what we have tested:
1. Fuel condition. Type and Octane possibly old fuel
Tested with new fuel and external tank. Also changed to a new fuel filter several times.
2. Propeller pitch or diameter, damaged blades
The boat did previously full WOT and 50 mph with the same propellers
3. Restricted fuel pickup tube or anti siphon valve Fuel System Test
Tried with an external tank and changed to new fuel pump.
4. Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
The engine is new and oil level seem fine.
5. Marine growth on hull and outdrive
No. Swiped the bottom clean and no difference
6. Wrong gear ratio in outdrive
The boat did previously full WOT and 50 mph with the same propellers and stern drive. The drive has been fully renovated by a Volvo Penta authorized dealer
7. Restricted carburetor air intake (clogged flame arrestor)
There is no filter and tried removing the flame arrester and with engine hatch open.
Also change to different new carburator. No difference.
8. Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
New flappers were installed, but upon inspection they sit correctly and moves freely and cannot block.
9. Poor cylinder compression Compression Test
The engine is brand new - less than 50h. A compression test was done on the engine and all were fine.
The tops were removed and pressure tested and all fine. Put back together with new gaskets (by professional)
10. Carburetor defective, or wrong type.
11. Fuel pump pressure and vacuum
Changed to new fuel pump. No difference. Have not measured pressure. Will do when boat is in water again.
12. Boat overloaded, improperly loaded, or improperly trimmed.
13. Engine Overheating
A carb engine - no warnings and temp is fine
14. Engine timing and ignition system operation
Have not tested, but new boat mechanic claims it cannot be timing. Will test with a stroboscope when boat is in the water.
15. Remote control cables and linkage for proper travel to open throttle plates fully.
Seems to work fine. Have also tested with pushing the levers directly on the carb. No difference.
I have exhausted friends and family and nearly 2 boat mechanics. I appreciate any help.
THanks
// Jens
THanks
// Jens
