trying to save some time trouble shooting. took a 6hp johnson that hadn't started in a while. put engine cleaner in gas, sea foamed it, changed gas tank, cleaned fuel pump, new plugs, made sure oil in cylinder, compression check was fine. replaced impellor to be safe started and ran well in tank. worked fine for a month. last time out (ran fine the day before) started sounding tinny and lost power. shut it off and brought it home to check it out. plugs a little fouled but not bad. changed them out didn't start. spark blue but wasn't even acting like it would fire. put mixture in cylinders still wouldn't fire. any ideas?
