Now I know the battery is very strong so i had some suspicions after doing some research that may be the stator that was causing clicking noise and the pieces of plastic flying out right before the wintertime.
My question to you is I want to pull the main crankshaft pulley off but I need to know what thread size bolts those are to put a wheel puller on ,there are 3 holes for bolts for the puller also has anyone ever experienced this situation I went into complete panic mode thinking the engine was seized removing the spark plugs and checking the engine oil which was not white. I'm praying and hoping that all it was is the stator collapsing falling apart while it was cold and jamming up against the engine block once I remove the pulley remove the shrapnel it should spend and start no problem. By the way i should also mention that I do have the alternator conversion kit so I really don't need a stator.
