Hi
I have an Envinrude 115 1980 with an on board fuel tank. I am wondering if the fuel line should be the same size all the way from the tank to the engine?? Currently the line comes from the tank 3/8". The connector through the boat at the back is 3/8".Connected to that is a 5/16" hose on it that goes to a 5/16"bulb. Then a 3/8" hose coming off the other side of the bulb to a 5/16" connector at the engine and then a 5/16 small hose running up to the screen. I took the screen off to see the size and it aculally looks like a 3/8" nipple. Sorry for all the mumbo jumbo. So should I replace all of this so it is 3/8" fuel line?? Should I put an in-line fuel filter before or after the bulb when I do this???
Thanks ...
Thanks ...
