Ryland3210
- Jul 21, 2015
- 60
I installed a flow meter before taking a long distance cruise two weeks ago, from Newburgh, New York up the Hudson River, Champlain Canal, Lake Champlain and Richelieu River and return. Heading north on New York 10% ethanol gas, 89 octane, the boat consistently used 1.6 GPH at 3500 HPM, for 1.29 MPG. The boat is a 2003, 7,000 pound 2855 Bayliner Cierra. The engine serial number is OL687277. It's a 5.7 liter, 260 HP EFI Mercruiser, single engine Bravo III I/O.
After refueling in Vermont on 91 octane ethanol free gasoline, it used 1.3 GPH at 3500 RPM, for 1.6 mpg. The engine also had significantly more power. Heading back south back into NY state, I refueled back on 10% ethanol 89 octane. When we got back on plane, the engine oscillated between the 1.3 and 1.6 GPH randomly any where from a few seconds to maybe 10 seconds. The throttle was held still while the boat accelerated on less GPH and decelerated on the higher GPH. YES, I really mean it! More fuel consumption and less power. After a while in this mode, the engine settled down to the low efficiency mode for the 50 miles at 3600 RPM for more than two hours all the way back to my home port. The best economy I saw on NY gas was 1.35 MPG up on plane. Economy was as good as 1.88 on VT gas. All test runs on smooth water with negligible wind. Ground speed by GPS, with the pitot tube gauge reading about the same. GPM readings were to three digits, e.g. 13.2
Things I tried: The flame arrestor was cleaned out with no effect. I unplugged the MAP sensor and plugged it back in, in case the connection was bad. Same with the air temp sensor. Took all the slack out of the throttle control mechanism and temporarily tightened it up firmly to hold it in position. Whenever turning on the ignition, it would always make two beeps and start right up. No more beeps after that.
