Re: erratic gas guage
Also, I have seen guys install those "one size fits all" senders, where you cut the wire. Well, those senders have 5 holes drilled in them in the shape of a pentagon (bolt holes) beleive it or not, they will only fit correctly one way, meaning the float coult be hitting something in the tank, and not floating all the way to the top of the tank. You can clock those senders by unbolting the center (where the guage sender wire fits) and spining the whole assembly so it floats free in the tank. If I had to put money on it, I would say rattana is right on the money, those senders are notorious for going bad
