ESA Inquiry - 76 OMC 235
zag123
I purchased a Pertronix Ignitor point conversion kit for my distributor. The instructions indicate that I must purchase and install resistors in the 12v lead going to the kit if I have shift interrupter. I don't know if they are referring to an ESA switch. Is the ESA the same thing? How would I know if I have one? Every reference to and ESA switch indicates that it is installed on the throttle linkage. I see nothing.
bruceb58
Re: ESA Inquiry - 76 OMC 235
You have an electric shift stringer. No ESA!
Boomyal
OMCs did not have ESA until the early 80's when they went to the full mechanical stringer outdrive. The hydro-mechanical unit, between the electric shift and the full mechanical did not have it either.
