Eska 15 - 90 WT gear oil?
11echo
I'm doing some fix-ups on my Gamefisher 15, replaced the impellor and drained the lower unit. I'm looking in the owner's manual and it says to replace the oil with 90WT Outboard motor lub! ...This any different then regular 90WT gear oil? (which I have sitting in my shop) Anybody know for sure? ...THX!
ezmobee
Re: Eska 15 - 90 WT gear oil?
From what I understand, you're fine to use what you have. However, the 90wt specifically made for outboard lower units has some additives to help it better survive a little water intrusion. (take from that what you will :p)
nwcove
i use 90wt gear oil in my small ob's.....never had a problem. ( just my experience).
