truckintyler
- Jun 26, 2010
- 77
the link i found... http://www.siliconchip.com.au/cms/A_110499/article.html
So i made this circuit on a board with point to point soldering , left the trigger coils in the modules and ran wires from them , you dont need any advance unit in the circuit because the advance is controlled by the magnet that sets off the trigger coil.
The only wires that come from out of the flywheel are two generator coil wires and two trigger coil wires.
so when i have time i will take pictures of what i did and some of you may be able to figure this out... BTW i have Never worked with electronics before so dont feel you cant do this,
pretty much what this does is abandon the eletronics that are in the module and moves them to an external unit .
i got great spark and cant wait to get this going, still need to clean the carb out and stuff.
on everything i spent maybe $80
