Re: Eska 15hp died today
It would be funnier if I wasn't livin' it, Mr. C. T-Ty, I think your probably right about heading to PITA town for $250 - If you commit to the 9.9, you have to keep parts, so you need a parts motor or two, and you've still got reliability problems. If you could make a flywheel hub out of delrin or phenolic, you'd still have the issue of the starter. I thought they used plastic because the teeth on the flywheel are aluminum. I have a Scott self propelled 6.5 hp walk behind mower with an electric starter, and I though about adapting the ring gear and starter to the 9.9, but the bracketry seems too complicated. Maybe the bracketry for a standard pull starter with a topside flywheel cup would be more do-able, but still a challenge. It probably wouldn't go under the cowl anymore either. To permanently solve these problems, ya gotta re-design, and fabricate a lot of stuff, or keep scarfing up spare parts. The truth is, that I haven't completely given up on the idea of the 9.9, because I think it would make my boat flat scat. I'll be interested to see what you decide to do.
