Estimating fuel usage
tie_one_on
Does anyone know where to find fuel estimated fuel usage for a boat. I'm looking at a 1988 28' Baha Weekend Crusier with twin 302 Ford 220 hp Crusader inboards with Velvet Drive transmissions. Trips are usually 30 miles round trip at cruising speed with about 6 hours of trolling. Thanks.
Juhl
Re: Estimating fuel usage
Expect app. 0,2L fuel per HK per Hour<br />ie. 2x 220 x 0,2L = 88L /H. If you have a powerdiagram you can se how many HK you take out at a specified no of RPM and the then you have your estimated fuel usage.
QC
Answers to this question are subjective at best unless you have the data to do Juhl's calcs. Most gasoline V8 small blocks burn around a gallon per hour (GPH) at idle, so your trolling use will depend on your speed and whether you run both or a single unit. Could be as much as 1.5 GPH each if you bump the revs up much.<br /><br />For the Cruise speed they typically burn around 10 - 15 GPH each between 3000 and 4000 RPM on a typical prop load curve.<br /><br />Juhl, What is HK? I know bhp, kW, PS etc. but not HK . . .
achris
More fish than mountain goat
QC,<br /><br />HK is the Danish way of abbreviating Horsepower. I think also Norwegian and Swedish too. <br /><br />Chris...........
tie_one_on
Thanks Juhl & Quietcat. This give me a starting point.
trog100
i have seen a formula that went.. 10% of horse power equals gallons per hour.. 10% of 200 hp would be twenty so it would burn twenty gallons per hour at WOT.. and so on..<br /><br />sounds a little high thow praps not..??<br /><br />trog100
QC
I just did some quick calcs with some Trailer Boats Mag test data. They range from 6.5% to 8.5% depending on engine etc. All was WOT GPH/rated bhp. There was one two-stroke Rotax that went over 9%.
