FreeBeeTony
- May 15, 2002
- 3,995
I recently bought a 24' Grady White Offshore with a 350 Magnum Mercruiser I/O. I believe it was rated at ~270HP at the crank. Boat never achieved WOT due to engine problems, it had a 15" prop on it. Went ~22mph at ~3200RPM's. Boat weights ~4000lbs w/ the engine.<br /><br />I converted the engine to a Vortec by replacing the heads and intake manifold. I believe this modification will push it to 310+ HP.<br /><br />What would/should the correct prop size be? If the 15" was correct for the 270HP, could I possibly go to a 17" and stay at the lower RPM?<br /><br />Not looking for a holeshot........just want to cruise at a decent speed at a relatively low RPM.
