Re: ETec 30
I will have to respectfully disagree on the dole fin. They're the ultimate in boating gimmickry/snake oil. Kinda like the coffee can exhausts and go-fast wings guys bolt on to their import cars in an attempt to gain a few mph. Not only do they not work, they make you look ridiculous. A properly mounted and trimmed motor, especially one as nice as an e-tec 30, will not a dole fin and should come with hydraulic trim/tilt, I believe. By installing one, you not only destroy/devalue the motor by drilling holes into it, but the stress they can create on the anti-vent plate, could cause it to break. The best way to eliminate porpoising and bring the bow down, is to redistribute the weight, trim the motor IN to the transom and/or use remotely adjustable trim tabs. LENCO are probably the best in the business. It mostly just takes lots of trial and error to find the best set up for your purposes, but dole fins and not the answer. There's a reason you never see professional guides, or anglers using them. Keep us posted on the e-etch. I hear great things about them. No break in period, lots of low end torque, good reliability and much lighter than their 4-stroke cousins.
