I have been having intermittent blanking of my i-Command gauge on my little 18 ft flats boat which has a 90 hp etec. In the past turning the system off then on again would allow it to power up. The other day, that did not work for 6 or so times until it finally did work but without fuel quantity indication. The boat is about 4 years old.
After messing with it at home after a day of scalloping, the whole system will not come on at all. I wonder if the gauge itself is bad as I have remade all the connections at the concentrator and power strip and still nothing. The fuel sender wiring has been inspected at the tank and at the connection to the fuel module and I see nothing there and where it hooks into the T connector.
I could rob an I- command gauge off my big boat and try it if need be.
Does anyone with I-command knowledge have any recommendations on where to look first.
Regards
Tom in Steinhatchee
Regards
Tom in Steinhatchee
