Re: Ethanol free gas
One additional point. Regardless what fuel you used in the past, if the fuel system had been ignored and is now full of debris, gum, varnish, use of ethanol blended fuel becomes a great fuel system cleaner and will remove this gunk. So for a period of time after starting use of E10 you may have fuel filter clogging issues. If you have an older boat, replacement of fuel line with ethanol tolerant versions will be about all that's needed. A carb rebuild with E10 tolerant parts would also be a good thing to do. Otherwise, the engine doesn't care what is exploding in its cylinders.
