I am trying to sell my boat (1971 Crestliner) with the above Engine. When I start the engine it idles but eventually revs to a full wide open roar within 3 or 4 minutes. The only way I can shut it down at this point is to disconnect the gas line into the engine- turning the key off and shutting off the battery switch does nothing. Being next to a complete moron when it comes to most things electronical, I somehow have a feeling that it has something to do with voltage? I know the mechanic who has worked on the boat before replaced the voltage regulator a couple of years ago- is this the same problem? Pretty embarrasing when you are showing the boat to a potential buyer and you can't shut the engine off !!!! All input would be greatly appreciated...thanks
Unplugged in Massachusetts..
