Evenrude outboard year and cleaning?
BRC
I am rebuilding a 15 horse evenrude.<br />Here is what is stamped on the welch plug.<br />E15RCSD<br />E0004098<br /><br />What year is this engine.<br />Also after pulling the cylinder head off there is lots of buildup of scale in the water ports and channels.<br />Other than a wire brush and elbow grease is there something you can soak in to remove this scale?
rolmops
Re: Evenrude outboard year and cleaning?
Hello.<br />Looks like a 1980.<br />Citric acid will disolve most calcium build up.If you do not know where to find this,take some lemon juice and add salt and there is your citric acid.
rickdb1boat
Might try a product called CLR. Avaiable at most discount stores. Works good on other calcium deposits around the house.
