Re: Ever patent anything?
What you really have to decide is if the cost of the patent going to be worth it over the long haul?
The marine industry is pretty competitive, so it may be worth it. If it is truly novel and you think that it will sell 50,000+ units per year and maintain that for a few years, a utility patent (can cost over $10K) would be the way to go. (There are a lot of design patents out there, but they are difficult to defend). You really need to do a market analysis and determine how many could be sold.
One of the first things I would recommend doing is conducting your own patent search to determine if there is any prior art. You can do this at the USPTO website, but I also like using
http://www.freepatentsonline.com/
Another resource I like to use is
http://ipwatchdog.com/
At a minimum, I would file a provisional patent application (as stated above) and you can use the "Patent Pending" designation. You will then have a year to reduce your idea to practice before going on to the next step (non-provisional application). Once you file the provisional, you can then start presenting to companies to see if they're willing to take it on. (I would have them sign a confidentiality agreement first even if you have Patent Pending designation). Given the economy, I don't know if companies will be making any tooling investments, so you may not have much luck.
