Hi all,<br />Periodically rebuilding a 1984 Evinrude 70Hp. Had a bit of trouble with idling/transition to power, so Ive taken off carbs for another clean (properly this time
), and now I cant remember exactly how you would set the idle mixture on these carbs?! The screw above the inlet has a sealing washer, so I pressume it has to be fully shut, but do you have to take it out every time to get to the idle jet adjust... then again, is this where the adjustment is anyway? <br />Thanks in advance,<br />Mitch
