Evinrude 100 Model 100293R
gribba
I am looking at buying a small run a bout with this motor on it. It has been sitting around for 2 years without use. It started nearly straight away but I am not sure about the water pump. Where does the water come out as I am used to motors where the outlet is high on the leg. I am also not sure how old it is.<br /><br />Gribba
JB
Re: Evinrude 100 Model 100293R
Hi, Gribba.<br /><br />That big old Rude is a 1972.<br /><br />If it has been sitting around for that long it definitely needs a new impeller, better a whole new water pump.<br /><br />I think that engine has a water tell-tale from the powerhead (Joe Reeves, please correct me if I am wrong) to verify good water flow.<br /><br />Good luck. :)
