Evinrude 115 HP Cylinder Wall
Chester797
I have a '85 Evinrude 115 V4 Crossflow that I am currently having to rebuild because of a detondation in the #1 Cylinder....damaged the piston really bad. When I took the cylinder head to be honed, the machinist told and showed me that the head was very clean and only damaged in the #1 Cylinder where there was a hairline crack in the cylinder wall between the exhaust ports. He advised me that he would have to sleeve this cylinder to repair it. I have had another machine shop tell me that they could mig weld the crack and bore or hone the cylinder for a better fix. I believe the sleeve is the better option but Im not a professional here. Also is $200 a good price for a sleeve job.
clanton
Re: Evinrude 115 HP Cylinder Wall
Ship the block to Precision in Clearwater. They will replace the sleeve and pressure test the block for waterleaks, if needed. Recommended by Joe Reeves. Phone 1-800-237-5947.
