TrevorRZ
- May 19, 2016
- 13
Long time lurker, first time poster and here's what I have going on: (Forgive me if I'm a bit long-winded, I'll put a TL/DR summary at the bottom)
Last Summer I bought my very first boat: a 99' Larson SEi Ski and Fish with a 115 Evinrude SPL. When I first got the boat, it was running a little rough; it wouldn't idle the best, would die when I put it into gear, seemed to "miss" here and there. I chalked this up to old gas and maybe it needed a carb cleaning that I was going to do over the winter.
The third time I had it out, the rings failed on cylinder #4. A little PO'ed, I saved up my cash and had the powerhead rebuilt over the winter (also had the carbs cleaned, impeller replaced, drained the old gas, and cleaned the gas lines) The first time I took it out after the rebuild (to break it in) the thing ran like a top. I followed the break-in procedure that the mechanic and Wiseco recommended to a T (Mix gas 25:1, first 4 hours was only at idle, then the next hour was at 1,500 rpm, the next hour, no more than 3,000 rpm, then 4 more hours at 3/4 throttle occasionally bringing it up to WOT for less than two mins).
Anyway, I was in my 8th hour or so of break in and I was going to bring it up WOT. It was running great for about a min at WOT and I was trimming the motor up to get it to plane out when it completely bogged down and died. I heard that sound before and feared for the worst. I go to turn the key and it won't turn over...as in, I heard the starter click, but the engine wouldn't turn. I hit the key again and at least hear the engine turn, but no spark. At this point, I'm 100% panicking as I was in the middle of the lake with a potentially blown up engine and the sun was going down. I hit the key one last time and the engine starts up, I let it idle for a second but when I put it in gear, it died (same as it was doing before I had it rebuilt). I tried once more and was able to get it into gear and brought it back to the dock (I didn't exceed 3000 RPM on my return trip. The engine did sound a bit "rougher" than it did before but this could just be my imagination as I was feeling kinda bummed out about my fresh rebuild.
I get back to the landing and let her idle at the dock while I back in the trailer. She was idling fine when I got back but as soon as I tried to put it in gear again, I ran into the same issue of it dying. I was finally able to get it in gear after about 4-5 attempts and got her loaded up.
Does anyone have any idea what's going on here? I'm planning on taking it out tomorrow to see if it's still running rough. I had a big weekend on the water planned with the family and I want to make sure everything is in working order before I have kids on the boat.
TL/DR: After running perfectly fine, my motor died suddenly about 8 hours into break in procedure. Started back up after a bit of a struggle with it not turning over but now it likes to die once I put it into gear out of idle. It has new gas, freshly cleaned carbs, new water impeller, seems to "pee" just fine.
Any thoughts and input would be greatly appreciated.
