I have an Evinrude 115/80 Jet drive that has newly rebuilt carb and has run well until recently. It runs at idle fine, but bogs at WOT after planing. I'm not getting a "low oil horn" and I've tried two different fuel tanks/lines and neither fixed the problem. It looks as if the VRO is drawing down the oil in the tank as it should. It can get onto a plane for a few minutes (and if you work it up on plane slowly, it might even stay that way). But, if you try to give it WOT (or anything close) it simply bogs down. Any thoughts on what to try next? Many thanks.
