The drive shaft space for the impeller key seems to be too low. The key ends up between the o-ring and the impeller causing the key to get damaged by the metal plate that surrounds the shaft. Seems to me that the key should be above the o-ring. See pic to explain. Also, I may have damaged the part that the drive shaft slips into on the top side of the shaft but can't find any mention of what it is or exactly where it is located or how to get to it to check for damage to possibly replace it. I've looked at the drawings on this site and I also have the Manual by SELOC of the J/Evinrude Outboards 1992-01 Repair Manual. Any help on both problems would be appreciated.
