So I'm pretty new to outboards, only had a couple in the past and never had to mess with them so not 100% what I'm doing, that said I'm reasonably familiar with engines in general and have a marine background (worked for Scott waterjet in nz for a number of years designing building and fitting out boats along with assembling jet)
The problem I'm having is with an early 90s 140ho V4 looper, no matter what I do I can't seem to bring the idle down, but the issue seems to being caused by 1 cylinder alone, pulled all the leads 1 by 1 and only 1 dramatically reduces revs, and running this cylinder alone revs extremely highly when compared to the other 3. Have cleaned the carbs and swapped to eliminate them as the issues, tried to find a leak with wd40 and brake clean but to no avail.
Any suggestions on what to look for next?? I'm stumped.
