maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 806
I have a 1992 evinrude 15 hp 2 STROKE VERY LOW HOURS . It bogs when you open the throttle quickly. It will bog and then rev up quickly. If you pull the CHOKE closed at the same time that you twist the throttle there is no bog at all. I went through the carb 2 times and replaced the SEALS and blew everything out with compressed air ( the carb was in good shape before the cleaning). I tried many different settings for the idle mixture KNOB but none helped. COMPRESSION IS dead even at 125 PSI PER CYLINDER. SPARK PLUGS are new. FUEL PUMP is new. I know the plastic carb tops can crack sometimes but this one appears fine. Anyone have a clue how to remedy this? I am open to all suggestions. Thanks
