Evinrude 150 xp help
Wayoung
i have a new to me out board, it is a Evinrude 150xp. How can I tell what year it is? Do they have electric fuel pumps? Or a fuel shut of
trailking82
Model number will tell you, it should be on a label stuck to trim and tilt bracket. The label also has your serial number on it.
In the event you cant find it on top of the powerhead should be a welsh plug or a freeze plug, model number is also stamped there.
The factory pump had wires going to it.----Those wires are for the alarm system.----Pumps are operated by changing crankcase pressure.
Wayoung
Thank you guys for the reply’s, I will use the chart to find the year. Did see the wires on the pump that’s why. Wondered about electric fuel pump
