I looked at a 150 HP Evinrude tonight, I'd like a project to work on, and this motor looks like a project. I have a bunch of questions.
I was a bit confused by the model number, as I'm used to model numbers like my 90 HP Johnson (J90TLCIM).
I found out this is a saltwater model, what is the difference?
I could not find the difference between the 150849 and the 150840 models. I assume the 849 is the 25" model, and the 840 is the 20" model?
I'd like to rebuild this motor, but if I do get it, and find out it's trashed, how many of the parts are interchangeable with my J90TLCIM outboard?
Would the lower unit from my J90TLCIM work on this 150849?
What portion of the lower unit is longer?
Does a saltwater model = stay away from it?
I once bought a 1988 Johnson 45 HP that was sometimes used in saltwater to rebuild it, and the bottom of the crankcase was corroded, I had to grind out the alum-oxide, weld, and re-machine. Should I just assume this motor is corroded on the inside, all the bolts will snap off, etc? I don't live anywhere near an ocean, but this motor must have started its life near one...
I can pick up this motor, with all the wiring & controls for ~$200. Worth it?
