I repaired my old 1974 Evin 25HP that had a seriour airleak at upper cranckshaftend, this winther. Its on my brotherinlaws boat now. We tested it on earmuffs - it seemed to run great.<br /><br />However after it run for some minutes, it shows a problem, most of the time it only iddles on one ? If you barely touch the trottle, both cyls are on. If you go to WOT in a snap - no problem, both cyls work beautifull, great acceleration. It runs like a champ on all rpm, soft and smooth - no problems, except iddle. What is the problem. The one cylinder turns on and off iddling, RMP going up and down. Compression and spark is fine. We did clean carb. It has run for 2 hrs now - no changes.<br /><br />Im confused, maybe i will change my name to oncylindertwin !!
