Evinrude 1975 85 hp electrical starting issue
BraydenAnthony
Can short out the starter and get it to spin, no shock when done. Replaced ignition also. Nothing happens when key is turned.
oldboat1
If the boat is new to you and you are trying to test it out, be aware that you can spin it over pretty easily with a piece of rope. Turn the key to the run position and leave the battery hooked up (be a good idea to check polarity too). Motor in neutral.
Crosbyman
have a buddy keep your key on START and wiggle, prod all the wiring you can reach..especially in flexing areas also check neutral switch and safety switch
if you get a reaction you have a broken wire....time to whip out a test lamps or volt ohm meter
surgery and a soldering iron may be required :)
Make certain all connections to the battery , and motor side are clean
see diagram V4 from the 70s... may help clean all connections in the fat connector
BraydenAnthony
Weathers been terrible, going to try this out tomorrow. Thanks!
Crosbyman
Assuming the diagram reflects your engine .... the selenoid gets a ground via the safety switch and the momentary 12V to energize it, comes from the "start" key via the neutral switch . Critical points are
  • the 12v supply feeding the key assembly
  • switch operation to apply 12V to the selenoid destination in START
  • Neutral switch continuity (wiggle the shifter in START mode)
  • Safety switch... probably OK
  • all wiring & flex points to & associated with the selenoid
  • junction contacts in the fat connector (open it and clean both sides)
let us know what you find :)
