evinrude 1976 85 horse
evinruder13
i finally fixed the monark went out 3 weeks ago.great day of fishing.so i wanted to go out this sat.so i launch everything is fine for about 5mins.then idle drops and then it stalls.so i check fuel filter and very lil debri.check fuel filter in motor and its clean.i check primer and its pumping fuel.so i decide to wait 10 minsand it starts right up it idles fine and then again it drops the idle and i tried to pump the primer to see if its getting fuel,and its full.so wondering if fuel pump is gone or do i need carb rebuild.any info would be appreciated.
ezeke
Re: evinrude 1976 85 horse
If the primer bulb was full and would not take more, then the float valves were working and the float bowls must have been full unless the float valve needles are sticking closed.
When you rebuild the carburetors, be sure to add the new needles that come in the kits and connect them to the float arms with the clips as shown in the thumbnail.
Check your ignition coils - sometimes they break down after warming up. If they are discolored, cracked, swollen or if the potting is deformed, it's best to replace them.
evinruder13
also do you think it might be from water in the tank.i dont have a water fuel seperater.the gas in the clear filter didnt look very good.we have been having rain and was wondering if that might be the prob.because 3 weeks b4 it was running great.no hiccups at all.should i install one b4 i get carbs redone?
ezeke
You could definitely have a problem with water - my nephew did this past spring with my old 1976 115.
We finally got it cleaned up but he got the water from the gas he bought at the marina which had just opened for the season.
It is a practical necessity to have a full-sized water separating fuel filter these days, and to dump it frequently.
evinruder13
should i start there b4 i go anyfurther.and what i explained to you,does that sound like water in the fuel.would the motor react that way.i just dont want to knowb4 i spend the money if it isnt necessary.do you agree?
ezeke
Start with the filter; if you have water in the tank, it will keep getting pulled into the engine because oil and gas float on water and the pickup is at the bottom of the tank.
emdsapmgr
You can remove the hose barb on the engine end of the fuel hose, and hand pump some fuel into a clear glass. Let it sit for 20 minutes-any water will settle to the bottom. You will be able to see if you have a fuel/water issue. Often, an engine will run with water contamination, but it will have no power.
evinruder13
this is where im gonna start,i went and bought water fuel separater,new sender,and some stuff that will break down the water that is in the tank,i made a mistake when i removed the sender (float)what was left of it anyways.i didnt replace the sender unit i just covered it back up with the sender unit cap.but i didnt replace the gasket,so the first time i took it out it ran great,then we got rain,after the rain,i took it out again,then it ran like crap,the water in the filter looked cloudy,so i think i got water in the take.completely my fault,i just get xcited to go boating.so i hope i didnt damage my engine ,i pray this works.
evinruder13
i would like to thank all the help from ezeke,emdaspmgr,i changed to a water fuel separater and put new sending unit (with gasket).and added some fluid that will break down water and help run through ,with no hiccups,had it running for like 20 min and it ran smooth.going fishing tomorrow,thanks
emdsapmgr
If the you have a lot of water in the tank, the separator may fill up with water soon: you can unscrew it and dump it into a container (to be discarded later.) Reuse the filter and you are good to go again.
