Evinrude 1977 25hp pulling to right
knackers63
Can someone tell me what this nylon part does it doesn't seem to connect to anything my boat pulls to right there is no adjustment near prop
That is a starter interlock.-----At this time it is disconnected.-----Has nothing to do with boat pulling to the right.
oldboat1
If the motor wants to move on its own, the flywheel might be rubbing slightly against the charge coil (air gap not quite right). Would be corrected by carefully reseating the coil. If the motor is kicking right or left like it's hitting something, you may have a lower unit gear issue.
Possibly, the load in the hull needs to be redistributed.
jimmbo
The crank shaft is rotating Clockwise when viewed from above, Newtons 3rd Law, For every action there is an equal and opposite Reaction. In this case the Block will try to rotate Counter Clockwise. This will push the rear of the prop to starboard which pushes the stern of the boat to Port and the bow will point to Starboard. The rotation of the prop is also making the motor rotate in that direction as well. In addition an engine trimmed in close to the transom will also result in making the engine swivel in that direction as well, if trimmed out from the transom, there will be a point where the forces are balanced, then further outward trim will cause a pull to Port.
There is a Friction Adjustment on the swivel bracket that can be adjusted to keep the engine from turning on its own
