I recently bought a boat with what I think is a 1983 Evinrude 60hp 2 cylinder engine (I made a different thread about the year on the engine before).
It idles fine but no real power during load so I did a compression test this evening, the top cylinder only got 50psi and the bottom got 150psi (seems a bit high?).
I tried putting some motor oil in the spark plug hole to see if the psi would raise, however no effect.
What could be wrong? What should be my next step? Head gasket? Junkyard? What happens if I continue running on one cylinder?
I'm hoping a new motor isn't the answer... any help is deeply appreciated.
