B.autry4711A
- Feb 24, 2005
- 176
Hello again,<br /><br />I have a quick question? I was taking the upper vent plug out of the lower leg unit to see if it takes a o-ring or teflon washer, anyway there was a little fine metal shavings on the magnetic pickup is this normal? Also this upper plug looks like it has a built in seal are they removalable. I want to change the lower leg unit oil and want to change the seals out on both plugs. My motor model number is E88MSLCER Thank you
