stalker170
- Apr 21, 2002
- 47
I have been dealing with this for a while and cannot find the issue. Motor runs perfect when you start it up, runs great all thru the power ban and at WOT. But after I get to my fishing hole and try to move, the motor stalls when I put it in gear. All I need to do is keep pushing in on the key to give it choke and I am all set. I would really like to get this fixed, because it can be a real pain when loading the boat or taking off after warm up. This is what I done so far:
1. Replaced all fuel lines and primer bulb.
2. Tried both onboard fuel tanks. (Just thought if anti siphon was bad in one, switching tanks would cure it)
3. Changed Trigger.
4. Change power pack.
5. Rebuilt all six carburetors.
6. Changed VOR pump.
7. Check reed valves, all seem perfect.
8. Did compression test, one side a little low so I replaced head gasket o rings, Great compression now, cylinder walls look perfect.
9. Changed temps switches.
10 Changed thermostats.
11. Replaced fuel switching valve.
12. Replaced spark plugs.
13. Replaced spark plug wire with high resistance ones.
14. Sprayed starting fluid around intake plate to see if the motor has vac leak
15. Checked vents in the tanks.
16. Timing is right on per the manual, tried advancing a little, no help.
Like said, not disabling by no means, just a major pain. I fish 15 tournaments a year and if I decided to upgrade boats, I need to get this fixed before I sell to anyone.
I have researched these forums, some posters are saying something about heat under the cowlings and vaporizing the gas causing air bubbles. I have had this boat and motor a long time. Just started doing this in the last two years. Same cowling and same motor, so if it is vaporizing, why did it just start doing it in the last two years. Also I read about increasing idle jets. Mine are fixed so I would have to go up in size. My tops fixed jets are 28's, bottom ones on the face of the carbs are 40's.
Andy help would be great.
Mark
3. Changed Trigger.
Mark
