I have an 1984 Evinrude 225hp V-6 outbaord. It starts and idles fine, and revs fine with no load. Once I go out on the water put the engine under load, it feels like half the engine cuts out, then cuts back in. I've cleaned all the contacts in the ignition system wiring and repaired the ground from the stbd side power pac that looked suspect, but no change. Also, the tach works intermittently, and when I tested it, I had no signal coming from the gray tach lead out of the rectifier. I've ordered 1 new power pac and a rectifier, but any help in tracking down this problem, or shortcuts, would be appreciated. Thanks!
