redfisher2003
- Jan 10, 2004
- 22
Last week I identified a weak spark in the #2 cylinder and I have tracked the problem to that set of points and condenser. When I try to set them I find play in the armature plate itself. While the plate rotates it also will move side to side, and the point gap changes considerably. There are four screws attaching the armature plate to a ring which rotates when the throttle is advanced. In my book it shows a nylon retainer that can be replaced on a different model than I have. Does anyone know if all magnetos have a nylon ring that insures alignment of the armature plate as it moves with the throttle? There was no nylon part with the ring that holds the armature plate down. The ring is held in place by a circular brass retainer that is screwed done by 3 screws to the powerhead. The ring seems metal but perhaps not. <br /><br />Also, anybody know if I can see a picture of this motor on the web to checkfor the part I think I need.
