boatingdudebmk
- Mar 27, 2013
- 24
Good Afternoon -
I have a problem with my outboard. Its a Evinrude E25ELCCM (1988 Electric Start, Long Shaft) with an electric priming/fuel pump gizmo. Anywho, the main problem that I have is that when I connect it to power (correct, full power) there is nothing at the turn of the key. As a back story, this engine has been completely underwater before, but I did my homework and took care of it like a baby, so that is not a problem. The new issue is the electrics. I will include pictures to aid you in your help
When I turn the key with power, nothing happens, but if i put the positive lead to the end on picture 2 (where I'm pointing) and attach the power, it starts without the key, and turns as soon as power is applied. So, there is something wrong with either 1.) The control box 2.) The solenoid or 3.) (im hoping its this one) the wires are not correctly aligned. Any help would be GREATLY APPRECIATED! This motor is going on the little red boat at the bottom.
